7020 3 point pin size |
Josh(NE)
Topic: 7020 3 point pin sizePosted: 14 Jun 2010 at 3:30pm |
anyone know the pin size on a 7020 3 point? I believe they are 1 1/8 on all three can anyone tell me for sure. thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake |
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1219 |
Posted: 14 Jun 2010 at 3:34pm |
That tractor should have a category 2 3pt hitch set up, in which case, you will have 1-1/8 inch lower links and a 1-inch upper link. This link should help:
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Josh(NE)
Posted: 14 Jun 2010 at 3:52pm |
tractor data list it as catagory 3/2 so I still don't know for sure. I thought there was somthing different about it than the strait cat.2 that is on the 190
Allis Express
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1008 |
Posted: 14 Jun 2010 at 3:59pm |
My 7020 is a cat. 3.
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 14 Jun 2010 at 4:31pm |
Its Catagory 3, the upper pin is a little smaller than the lower two. I dont remember the size right off hand.
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 14 Jun 2010 at 5:09pm |
Should be cat.3,use bushings for cat.2 implements.
Hurst
Posted: 14 Jun 2010 at 5:25pm |
Well, I learned something new today.
Hurst
5800 Hours |
michaelwis
Posted: 14 Jun 2010 at 5:29pm |
that is correct ..same as my 7040
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
