HELP my 200 won't move
Dave/cvny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Topic: HELP my 200 won't move
    Posted: 16 May 2017 at 8:10pm
The transmission seems to be turning so I am thinking that the power director is slipping , is there anything I can try before I send it to a shop to fix it? Thanks in advance
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:57pm
check the pressure on the pd clutch pacs - make sure the linkage is shifting the valve all the way in and out both ways and that you do have oil in the PD side...
Edited by tbran - 16 May 2017 at 10:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:42am
Tbran, has your answer. Pin fell out of linkage.    MACK
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:52am
While what the others have suggested is a likely cause, your statement is throwing me off.  If the transmission is turning, the pd would not be slipping.  Have you verified the transmisison is turning other than in neutral.  how do you know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 1:23pm
As far as being able to tell if the transmission is turning, when you shift it you can feel the gears turning. No the pins haven't come out of the linkage! Maybe the clutch went out of it? At this point all I know is that it will only move on level ground and I can walk faster than it will move!
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 4:10pm
Put the trans in gear engage the pto let the main clutch out and have someone watch the pto  if pto doesn't turn your main clutch is slipping. If pto turns the PD is slipping.
turbocharged
This page was generated in 0.116 seconds.
