200 injector pump
alc609 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Topic: 200 injector pump
    Posted: 16 May 2017 at 1:29pm
needing to pull injector pump off my 200 for rebuild. there is a 1/2" x 1 1/2" (roughly) on side of pump. i took plate off and lined up the two marks in the pump, are these the only timing marks to line up? or should i look at something else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 10:15pm
There are timing marks on front crank pulley. You won't them if you mark front of pump to mounting plate.     MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 7:31am
If you line up the marks in the pump window, that is all that is needed. Timing will be as it was when the pump is reinstalled.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 7:34am
once pump marks are lined up, you just verify where it was timed by looking at the marks on the front pulley or flywheel. This way you can make the necessary correction upon installation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 7:51pm
So, if I have the window marks aligned on the pump, I'm good? And just line them back up before I reinstalled the pump? And as long as nothing is moved on the the motor it will go right back the way it came off, correct? Thanks
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 7:57pm
I would look at your timing marks as another point of reference too. Then there is the dot on the shaft tang that you should note once you pull the pump. I tend to overthink things but.....
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:14pm
basically yes. But, when putting the rebuilt pump back on, why not ensure it's set exactly right. There's a couple different timing specs for the 200 based on what pump you have.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:19pm
Get everything in place before you pull the pump. Then add some marks if you want too. Always mark your trail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:24pm
Best thing to do is get it rebuilt and then check in on this subject
Edited by DougG - 17 May 2017 at 9:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 10:54pm
Getting it rebuilt, but didn't want to just take it off and be a nightmare to go back on. Especially with limited knowledge of this
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 10:56pm
How do you post a picture on here?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 4:30am
You post a photo by clicking on the button indicated in the photo below.  this only works if you DO NOT use "quick reply".
After you click on that button, a pop-up will ask you to choose a file from your computer.  .jpeg files seem to work best for me.
