One of the WD's runs! Oil problem...
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: One of the WD's runs! Oil problem...
    Posted: 13 Jun 2010 at 9:42pm
Well I got the C/b running pretty good so I turned my attention to one of the WD's. I tore the mag apart and cleaned it up. Drained the old gas and changed the oil. I pulled the valve cover off to find a recently overhauled head. New valves, locks and freeze plugs from what I can tell. I cranked her up and she fired right up. However, I let it run about thirty seconds and do not have any oil pressure to the valve train. I also pulled the oil filter and have no oil there either.
What is the best way to prime a WD oil pump?
Is it common for oil pump shafts to break or some other type of oil pump failure on a wd?
Hoping I don't have to drop the pan. If I do, no biggie. I have plenty of parts around to fix her up.
Thanks, Jesse.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 9:45pm
I found someone did not tighten a compression fitting once when head was overhauled
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 12:37am
Did you put oil back in it? LOL.  Don't want to ruin your day but I bought a running '48 WD years ago with no oil pressure gauge.  Got it home, changed oil (nasty) and put on a gauge, no pressure.  Found the oil pump locked up and stripped the teeth off the cam.  Hope your luck is better than mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 6:07am
I have so little money invested in this, if thats what happened, then thats what happened. I will check that and see what I find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 8:24pm
What I did on the WD that I got that was tight was I took off the oil filter and took the small tube off of where the oil comes out and then filled up the tube hole with oil from a squirt oil can until no more would go down.  I then cranked it over with the starter but with the ignition off so it wouldn't start unti some started to squirt back.  I then reassembled the oil filter and cranked it until I had oil up in the valve train.   Once I had oil pressure on the gauge and oil in the valvetrain, I then started it up.  I don't know if that method will work for you but it did work for me.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 8:37pm
want run long with no oiling going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 9:04pm
Pankey. You sir are a genius.  Maybe even a rocket scientist. No one speaks the obvious more than you. Thanks for your sharing your vast knowledge with us.
Chuck, I thought I would pump some oil down there and see if that works. If not I will tear it down and see what is going on. I do not know the history of this tractor. Maybe this is way it was abandoned. Sure sounded like it ran good when it popped off. But it only ran a little bit before I shut her down. Hopefully it is a good one still.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 7:04am
Yes not everyone is as intellegent as I to make a air /oil pressurized bottle that hooks in to where the oil gauge is originally on 201 and 226 engines to bring the oil pressure up on a engine that hasnt been run in a while. Their bearings usually tell on them though.
Edited by mlpankey - 15 Jun 2010 at 7:12am
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2010 at 7:49am
Something else simple you might check, I have seen the little oil lines get blockages in them after setting for a long time.  You might take them off and blow through them to check.  Also, make sure that you are using a gauge that you know works.  I have ran into bad gauges before also.
