38 B axle seals
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Topic: 38 B axle seals
    Posted: 13 Jun 2010 at 5:44pm
A friend is restoring a 38 B and finds that the axle seals are a felt/rope type seal. Does anyone know of a replacement for these. Thanks for any help we can get. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 5:53pm
the replacement seals will be rubber. you can get them from  AGCO, vendors on this site or buy from a bearing warehouse... i can look up the number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 5:55pm
Rear axle bull gear shaft
Inner brg                                                          tapper roller            14138A (brg)-14276 (race)
Outer brg                     TIMKIN                      tapper roller             368 (brg)   -- 362 (race)
Outer seal                     2.500-3.548                 .500 lip seal             CR 25065         NAT415001
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2010 at 7:13am
SSteve I may not have been clear on the axle seals, the 38 has a round cast area for the seal to sit in, not just a straight cut machined area like most Bs. should he try to find a later casting.  Cal in Ct.
