"Inside" wheel weights on the outside?
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: "Inside" wheel weights on the outside?
    Posted: 05 May 2017 at 4:43pm
Ok, so after spending the afternoon wrestling those 300+ pound Rowe wheel weights on to my 8030 I discovered that they are just thick enough to prevent me from getting an impact socket on the nut for the inside u-bolt for my dual hubs unless I push the wheel centers in too far to be safe so I am back to the drawing board. I have a handful of the 400 pounders that I have always had mounted on the "inside". I don't have the right equipment to try to pull my rims and centers off to put those on the inside. Any theoretical reason why I couldn't mount one of those "inside" weights on the "outside" of my centers and pick up a couple of inches for my dual hubs?
Edited by pdh - 05 May 2017 at 4:45pm
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 5:20pm
As long as you can bolt them on, they don't interfere with anything, and most importantly, the surfaces around the bolt holes actually touch you should be just fine.  If the weights don't fit up at the holes, but rather are supported say near the center, and you tighten them up too much, you can risk breaking your wheel center.
Still in use:
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 7:17pm
Ive seen inside 1000 pound d21 weights on inside and outside
