Allis chalmers m crawler track removal tips
ew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ew Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers m crawler track removal tips
    Posted: 04 May 2017 at 8:11pm
Do any of you have tips on removing the tracks on a m crawler?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2017 at 11:13pm
Big hammer(10 lb) and beat the master pin out and your good to go. Works best to get master pin backed with the sprocket or idler. All kind of ways to make a punch holder so helper is out of harms way. If your working alone fab a way bolt a pipe to hold punch,and it bolted to track shoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 7:03am
I used a cold rolled drift in a piece of pipe welded to the backside of my track shoes, could have made a clamp fixture with the shoes removed to hang it on the chain link then wail away with a Big Hammer.  I have a 20# but it gives as much beating as delivers.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 8:09am
x2 on the pipe.  i use a section large enough to go around master pin and buck track link with it tight up against rear housing, while having to track pushed outward on sprocket to eliminate bouncing.  makes a huge difference  then a good section of shaft welded to a handle  a helper can hold while you pound away
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:24am
Got a 20#er myself. It will wear you out. But it will move stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 11:10pm
I just filled the bucket on my HD5, backed up while turning left. that was always a fast way to get the track off it! lol
