Pulling the B part II
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Pulling the B part II
    Posted: 12 Jun 2010 at 8:00pm
I pulled again at the Woodstock VA fairgrounds and got to meet Brett Phillips! Bring that C the next time
They have a gravel track there and I was the first puller in the 2500 3 mph class. I weighed in at 2580 (100 more than Thursday for some reason) and I had to drop a wheel weight to be under 2500.
1st gear and I spun the left side the whole time but I beat the Oliver 60 Row Crop in my class by 43'. Was only 2 of us so I had a 50/50 chance at winning!
And to the track crew who said a B would never pull that sled, HA!
Was a fun time, but blistering hot.
[TUBE]-BDuYStbaL4[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:10pm
Nice pull but what the heck is all that wobble in the front end when you pulled away? LOL
Edited by CTuckerNWIL - 12 Jun 2010 at 8:11pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:24pm
When I run onto a scales that weighed me heavy when I knew it wasn't I would take the back to my trailer and wait a little while and weigh it again without removing weight. If they got the same weight the second time I would remove some weight.  I have removed a 100 pound wheel weight and went back and was 100 pounds under weight. Put the 100 pound weight back on weighed again and made weight. I never took having my tractors under weight lightly. Most of the time from scale to scale there would only be a coupla pounds difference.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:29pm
The "Drawbar Cam" perspective is neat.  It really shows how much noise the final drives generate on a B.  I'm sure that the finals on my C would be even noisier.  I need to find another standard weight rear wheel center for my C so I can join you in that weight class.  Then there will be a 33-1/3% chance of getting a first place trophy...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:58pm
Those cast wheel weights are heavy and over the years have loosened the front end a little!
I'd like the competition Brett!
Charlie
This page was generated in 0.083 seconds.
