Dash in 200 ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Dash in 200 ????
    Posted: 16 Apr 2017 at 8:34pm
I have a allis 200 with I think year round cab. My question is can you slip the top cover of dash out from under the cab bracket that goes over it. Hope that's explained good enough lol. I want to hook a wire up behind dash.
Thanks
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 8:39pm
Should be able to. Even with a factory cab, it is a tight fit, but it came out. I put 1/4" fender nuts on mine. 1/4" bolts hold down the cover tighter than screws.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 9:09pm
Ok thanks
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 9:11pm
Put your steering down low and on a 200 extend it out and if nobody bolted anything else in the way you can slide it into the cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2017 at 9:20pm
Ok thanks again
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2017 at 10:41am
Most cabs have a removable plate on the front around the dash cover.
