WD Transmission - Slid Gear?
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: WD Transmission - Slid Gear?
    Posted: 11 Apr 2017 at 7:49pm
Had to pull the tower off of my Syncro tran WD as align pins dropped out into transmission. NathanSD did tell me had to be in 2nd gear to pull tower off, and that worked very well.  Rewelded and worked on shift lever ball again. Tower went back on quite well, had to jiggle a little, did not have to force at all, engaged clutch and used big screwdriver to shift back to neutral, put shift lever back in and started tractor.  STILL appears to be stuck in a gear.  Moves forward. No reverse.
Could I have slid a gear somehow when I put the tower back on that caused this problem?
All forks line up as if in neutral.
Please help!
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:25pm
Do you have a natural? Will it move forward in all four gears, or always moves forward when clutch is engaged no mater where gear shift is?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 12:47am
No neutral even tho gate is in neutral position.  Seems like able to shift into 1st, 4th, reverse, but all move forward.  When looking down into neutral gate thru shifter hole without shift lever installed, seems like gate is more toward rear of tractor, than centered as it seemed like it was before, but maybe I just never paid this close of attention to it before when I put screwdriver in to line up the forks, and reinstall lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 7:48am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 8:09am
With top off, slide all gears to their natural posies. Start tractor and let clutch out slow. If you have natural then, you are not getting all shifters lined.
 If this is a WD with straight cut gears or later syncromash gears?
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:15am
Late WD with syncro gears.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 9:35am
 Make sure that the forks slide into the groove in each coupler.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 4:30pm
Seemed like forks were right in line with the grooves when I lined the tower up before dropping it down, but think I will try to get it in 2nd gear again, and pull the tower off again.  I have never done anything like this before, so am kind of working blind, unfortunately.  I'm sure some of the members here could just look down at the gears and tell me what is wrong, but unfortunately, I can't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2017 at 7:51am
bump
