2 ?
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: 2 ?
    Posted: 11 Jun 2010 at 5:02am
I have two questions if you couldnt tell. first one is what do i run for oil in the rear of a allis 190 is it 80/90 weight gear oil or do i run hydraulic oil in the rearend.
The second question is i just aquired a white top little round baler that had been restored and im going to try it out here soon does anyone have any pointers to help me get started like do i run a my wd45 full throttle or do i run it half any help on what i need to get started.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 10:27am
The 190 should have trans/hydraulic in the rear end and 80/90 in the bull gears.  As far as the Roto Baler, fist make sure that your brake is free.  I have found when bailing that they seem to work best at full speed.  If you need any help or have any questions, send me a message.
  Good luck,
 Joe
Life is simpler when you plow around the stump.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 10:39am
rake the windrow as wide as you can. Not tall, but wide. Like you would throw 2 windrows just together-- beside each other---just touching. This makes for a more uniform bale and loads it evenly. My Dad bought one new in 1947 and used it until 1995. As you can tell, my job was raking!
This page was generated in 0.258 seconds.
