912 hydro help
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: 912 hydro help
    Posted: 01 Apr 2017 at 9:35pm
i looked at the 912 today and i noticed these things:
missing gas tank, frozen levers, rotted steering wheel (turns freely on shaft), no very bad rust      it looks pretty good besides some missing pieces.     im going to take off the engine and bring it home to work on it. if it run, then ill work on the tractor.    but here is my question     what should i do about the missing gas tank, frozen levers and petal ect    photos below
Edited by NATHAN CAIRNS - 01 Apr 2017 at 10:00pm
B212, WD45, B, 912 Hydro
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 9:50pm
ON THIS PICTURE I WOULD LIKE TO KNOW IF THE HOLE WHERE THE GEARSHIFT WOULD BE NA 212 SHOULD BE THERE
Edited by NATHAN CAIRNS - 01 Apr 2017 at 9:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 10:31pm
There's no gear shift on a hydro. Just the same frame with different decals that cover that part of frame. The bigger lever on right is the hydro lever. Which is what moves tractor. Get yourself a bunch of penetrating oil and soak all your moving parts while you work on motor. I should have a salvaged gas tank for it.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:57pm
Nathan,
That hole is where the shuttle transmission gear shift comes through.
I have a 712 tractor with the shuttle shift and it gets right along in 4th gear! Wink
How blessed we are by HIS GRACE!
