I-400/D10 Temperature Gauge
D10SERIESIII View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10SERIESIII Quote  Post ReplyReply Direct Link To This Post Topic: I-400/D10 Temperature Gauge
    Posted: 10 Jun 2010 at 1:00pm
I was wondering if everyone had any issues with the new Allis Chalmers temperature gauges.  I have D10 Series II and I-400 and replaced both tractors with the new Allis Chalmers temperature gauge and experiencing the same problem in both tractors when I engage the PTO and the tractor is running at ¾ to full speed the temperature gauge is measuring around 220 however I did not think the engine was overheating so I took Inferred Laser Thermometer gun and came back at about 160.  So I wondering if everyone was experience this kind of problem with Allis Chalmers Temperature gauge?  The gauge can be used in I-400, D10, D12, D14, D15, and D17.  I was thinking maybe the gauge in not calibrated correctly?  I’m thinking I installed the gauge correctly but maybe not.  Any thoughts?
Thanks,
John
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 2:08pm
Infared heat guns are notoriously inaccurate.  Every summer I am tortured by heat guns.  I would trust the gage first.
cheers,
Creek
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 2:46pm
Put the sensing part in boiling water  wa-la  212 deg or close enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10SERIESIII Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 4:35pm
Cheek,
If the Laser gun says 160 and 160 is the correct running temp than the gauge is incorrect.  I also checked different parts of the engine with the gun and was temp was the same at 160 not 220.  I don't understand how the gauge is reading 220?  It's almost 60 degree difference?  I can't believe I'm the only one who experience this problem?
Thanks,
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote D10SERIESIII Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 10:49am
I was wondering if anyone have any thoughts on my temperature Gauge issue?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 11:24am
I have used a meat thermometer placed in the filler neck hole.
Remember the gauge is sensing next to an exhaust port and will show warmer than in the filler neck.
The late 149-160 heads were tapped at the thermostat housing for temperature sensor.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 10:08pm
I would call whoever you bought them from and see what they have to say.
