tilt steering mechanism on 190xt
troy(el paso, il) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Topic: tilt steering mechanism on 190xt
    Posted: 12 Mar 2017 at 8:19am
Hi All-
Does anyone have an exploded view or parts diagram of the tilt steering mechanism on a 190xt?  Going to attempt to fix mine, but haven't been underneath the steering column yet to take a look at the mechanism.  Just trying to figure out what I'm getting into.....
Thanks in advance,
Troy
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 9:19am
What are you doing under there?    MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 9:37am
It doesn't tilt, right?
Most likely, the shaft that the steering column pivots on is seized up - mine was.  See the picture below.  Loosen the nut at the bottom, this will relax the clamp that holds it in place.  Try moving the column up and down.  IF it doesn't move, it is seized.  Use lots of oil to get it moving freely. After that, snug the nut up again and try moving the linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 4:08pm
Myron, I will try that.  My steering column just slides up and down in the slot without locking.   Does the mechanism allow to lock the steering column in different positions?
Thanks....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 9:26pm
Ok, you have the opposite problem that I had.  Try tightening the castle nut.  When pulling out on the knob, you should be able to move the column and should lock when you release it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 10:12pm
There is two little round brake pads in there. Could have broken and fell out.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote troy(el paso, il) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 5:51am
Ok,.........thanks Mack and Myron for the help....
Troy
