Diffrence between a 653 and H4
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: Diffrence between a 653 and H4
    Posted: 11 Mar 2017 at 7:53am
Can someone tell me the difference between a 653 and a H4 . years mad the same. motor the same .  tranny same etc. thanks  norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 11:38am
lever steer / pedal steer - top track carrier roller stand one faces in other faces out .
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 11:49am
Instrumentation on the Dash is similar - layout of gauges differs. Also HD4 has dash lighting two locations so gauges can be seen at night.
On HD4 Loader Machines vs. 655 Loader there was a serial number break on the loader cylinders used.
HD4 Series II became the basis for the 650 series machines. Engine horsepower was increased from 52 HP in the HD4 to 59 HP in the 650 series.
Track Assemblies changed as tractor weight increased from 8,500 to 8,900 pounds.
Excerpts above from Allis Chalmers Construction Machinery and Industrial Equipment - author Norm Swinford.
Edited by orangeman - 11 Mar 2017 at 12:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 1:35pm
Very interesting.  Thanks
rob6161974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rob6161974 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2017 at 4:36pm
does anyone know where the converter filter and transmission filter is located? Also I'm having trouble with my machine. it goes great in forward but will not go into reverse. any ideas??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 7:44pm
shuttle valve problem - check for broken spring in the unit on left side of operators station - has spring on each side of valve shuttle - known to break
This page was generated in 0.484 seconds.
