230 gas block in diesel |
groundhog55
Topic: 230 gas block in dieselPosted: 09 Mar 2017 at 4:12pm |
dawntreader74
Posted: 09 Mar 2017 at 4:42pm |
boy'' she looks nice' steve
groundhog55
Posted: 10 Mar 2017 at 7:51am |
click on the picture and you can see all photos
cwhit
Posted: 10 Mar 2017 at 11:48am |
I really like your front weight bracket. Gives me an idea.......
dt1050
Joined: 05 Jul 2011 Location: central pa Points: 1078 |
Posted: 10 Mar 2017 at 1:39pm |
ok, time to give me my tractor back, I only left you barrow it
. very very nice machine. |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10997 |
Posted: 10 Mar 2017 at 2:52pm |
Yes, really nice looking machine
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 10 Mar 2017 at 8:09pm |
Why the smoke when it's supposed to be a gasser. Just askin'. Sure does look good. I don't think I would have had enough nerve to put it in the field.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4547 |
Posted: 11 Mar 2017 at 6:16am |
Gas block but it is a diesel. Looks like it has block mounted water pump and you blocked the water pump mount on the head. Does this combo works well?
MACK
Posted: 11 Mar 2017 at 6:57am |
230 gas and diesel blocks are the same. There was some gas engines that had the two oil filter boses casted on block but not drilled for 45 diesel. MACK
Calvin Schmidt
Posted: 11 Mar 2017 at 9:34am |
WE also used a 262 gas block for a D-17 diesel rebuild and friend used a gas block used in a D-19 diesel rebuild
LeonR2013
Posted: 11 Mar 2017 at 2:49pm |
Well I'll be darned. Could a 292 be done the same way? And I guess you could just leave it a gasser with no problem.
MACK
Posted: 11 Mar 2017 at 10:04pm |
292 was a GM. MACK
