190xt Turbo
farmboy98 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy98 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt Turbo
    Posted: 07 Mar 2017 at 10:32am
I am rebuilding the engine in my 190xt series 3 right now and I am looking for suggestions for a turbo that can replace the stock turbo as mine is leaking from the seals. I have heard of swapping an hx35 onto one but I don't know if the exhaust flanges are the same or not. Any input is appreciated.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 8:53pm
I bought one from A&I.  It bolts right on, but I had to switch out the lines from a Series III as I have a series I with the original Rayjay.  Sounds good on top of a completely rebuilt engine, but I have only had it running for around 30 minutes so far.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:41am
Best bet is to do as DSeries4 did and get a Airresearch (Garret) replacement turbo from either an aftermarket or Agco dealer.  My local Agco dealer has gotten me my last two turbos for 426's and they were only around $450-500 each (a couple years ago) sourced from an aftermarket supplier they deal with and not an Agco part.  I had checked into changing to a different turbo and after researching as much as I could, any possible gain would be very minimal if you did gain (on the 426).  The turbo supplier you choose to use should also list a conversion kit for converting from the Ray Jay to the Airresearch, the kit just consists of a short drain tube, a couple fittings for the new oil hoses, and some hose to supply oil and drain the oil from the turbo.  If you follow the link, it is to a page for a turbo and conversion kit, I think they are well overpriced on the kit, but is to show a "nicer" conversion than the one I had that just used hoses instead of the metal lines.
http://www.spencerdiesel.com/Detail.asp?Part=SDTMW-%3EGAR%20190XT%20KIT
Your series 3 should have the Airresearch turbo though and shouldn't need the conversion kit, here is the listing that place had for just the turbo.  Again I think the other supplier my local dealer used was cheaper, but it was a couple years ago and the prices may have went up since then.
The following link is to the A&I turbo which would be the same as the one above.
This page was generated in 0.045 seconds.
