Noisy/growling finals
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Topic: Noisy/growling finals
    Posted: 05 Jun 2010 at 10:30am
I purchased a C recently, knowing it had noisy/growling finals.  As I recall this was discussed a while ago and other than new gears, moving the finals to the other side was a mentioned option. Has this been done, with good results?
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 10:37am
I switch final drive gears on an M Farmall once. The guy said it howled bad. Afterwards he said it was much better and only howled in reverse. I would check out bearings first and look things over.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 11:55am
I've got a CA that was used very little its whole life and it growls also.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 4:36pm
I've noticed that some of my A-Cs growl whenever a green tractor drives past the house... ???
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 6:17pm
If the tractor sat for a long time, the bearing races in the final drives can get rusted and ruff. Also make sure you have oil in the final drive. I noticed the other day one of the final drives where leaking on my CA. It had rusted a hole through. Well I had checked the level in it over the winter but when I took the pan off to fix the hole it had about half cup of oil on top of 2 inches of water.
Leon B MO
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 7:19pm
For the amount of work involved in changing the final drive bearings I can't imagine a good reason to not just buy new bearings and races. I don't know current prices, but I expect you could buy them for 20 to 30 dollars per side.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 10:14am
Can't believe I didn't get even a snicker...  tough crowd!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 10:18am
LOL!!!!!!! Big Dollars$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
I can't remeber what model it was but the bearings were $300.00 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 11:41am
I am gathering parts for a project tractor, just checking options. May be a big game of mix and match.  Could end up with a combo BBC, a CBC, or a BCC.
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 2:28pm
Bearings aren't cheap. To replace the bearings and seals on my D17D, I spent about $300.
JohnDNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnDNY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 3:21pm
Don't buy your bearings from a dealer and pay the big price. You'll pay half of that from a bearing distributor. I have many times and the price is considerably cheaper. Try an outfit like Kaman Bearing Co. They sell to the public.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 4:08pm
Every tractor Ive been round with final drives has growled ;  WD,s \WD 45,s \170\175\180\185,s ; it was either the finals or the transmission ; never gave any trouble on any ; so keep em rolling !!!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 4:14pm
Dave, I thought that was pretty funny - got two snickers here in Massachusetts. As to cost - I go to a local bearing/seal outfit rather than AGCO. Of course, my tractors don't get much use, so any quality difference won't surface until long after I'm done using them!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 4:24pm
Dave K, better get your ears checked. I was snickering here. Dave(MA) there might not be any quality difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 4:31pm
Hee hee... I'll rinse 'em out, just to make sure.  They probably mark their territory a little bit too, but it ain't 'cause they're scared.
I'm sure that when these beasties were built, the metal used in the bearings was top-notch, but I'd be willing to bet that the modern replacements, particularly those not coming from third-world manufacture, are as good, if not better, on account of modern process control.
Tucker- you said you reversed the gears... you mean... flipped the pinions, or flipped both outer reduction housings... and this quieted it down except for reverse?  So I gather that the growl was apparently wear on the final drive gears?  are they straight-cut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 5:03pm
Yep, straight cut, which tend to be noisy anyway. I can't remember if I switched sides but I reversed the final drive bull gears so it powered off the opposite side of the teeth. I questioned whether it would do any good but the guy wanted to try it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:24pm
When I said 20 to 30 dollars per side I meant per inner and outer set of bearings and races. Looking at some on-line tractor sites that is about right. If you replace the inner and outer final drive bearing and axle bearings and seals on both sides you would probably be looking at 250 to 300 dollars from a quick glance at prices.
If you take the bearings out a go to a local bearing house you should be able to get the best prices. Either way for the labor and time it takes to change the final drive bearings I can't imagine trying to swap sides and then having to do it again. That is my 2 cents worth.
Even with new bearings they are not going to be quiet. It depends on just how noisy they are as to whether they really need changing. I am assuming they are very noisy, and the decision has been made that something has to be done. If that is the case the only real option I see that is not gambling is to go with new bearings.
