616 Alternate wheels/tires??
bamaboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Topic: 616 Alternate wheels/tires??
    Posted: 22 Jan 2017 at 6:45pm
I'm still trying to figure out a way to get more traction in sand for pulling stumps. Could anyone tell me if these would fit my 616?
http://www.ebay.com/itm/8-3-24-Tractor-Tires-and-Rims-Nice-6bolt-Compact-JohnDeere-etc-/332093366026?hash=item4d524e9f0a:g:EhoAAOSwiONYPOB-
Or would the 6-lug bolt pattern match up to Chevy or Toyota wheel?
Edited by bamaboy - 22 Jan 2017 at 7:00pm
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 11:32pm
The rear tires on these series tractors normally are 15" and those were 24".
I believe the flotation tires on these tractors are 31 x 15.5 x 15.
15" ag tires would probably give you more traction.  Wheel weights would also help.
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 8:38am
Alan look for a set of 8/9.50x16 bar tires they would give you better grip than a truck tire, I got a set off a John Deere 4100. bolt pattern is 6 on 6. Right now I have a set of 29x12.50x15 bar tires on my 720  and they work fairly nice, lot of garden work. Not sure what size trees your pulling but I can't seem to get enough weight on to keep from spinning. Remember these are straight cut gears in trans and wouldn't take a lot to strip the teeth off, I have a parts tractor that has a couple of teeth missing, not sure how it happened. Just think that if you get into a hard pull they may break.
Edited by ac720nut - 23 Jan 2017 at 8:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamaboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 9:33am
I have 15-20" stumps, I have a big 4:1 and a smaller 5:1 block-n-tackle set-up, I think I could (with many resets) pull them with a hand winch. Thanks for the info, I had found a pair of 6-4.5 wheels, now I know to pass.
This page was generated in 0.079 seconds.
