HD11 SEAL Crossreference
jchance View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Topic: HD11 SEAL Crossreference
    Posted: 15 Jan 2017 at 4:24am
Hi,
does anyone know  a cross reference for a seal for HD11 the Allis Chalmers part number is 620279 or 70620279.
Original Part is $185 each and i need two of them, would much prefer an aftermarket version however i am unsure of the specs of the original part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 8:08am
Just went to part book to ID the seal. Appears by descriptor page 218 to be a two piece probably a steel ring with a packing ring of rawhide(most likely) or a o-ring. I seriously doubt after market would handle that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 8:42am
after market with the same specs is what im chasing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 9:16am
That is what I meant in last post, never seen a packing if it is by aftermarket save hydraulic cylinders. You may want to take the remnant pieces to a hydraulics shop to have made as not many if any still make multi-piece rawhide seals save by hand.
Allis final drive seals are as rare and odd. Are a mix of two steel washers with neoprene rubber fibrous donut between with springs embedded. Your 11 has these and they are not available by anyone else either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 9:17am
To add, it most likely have been a weeping seal to lubricate the outer bearing on the clutch shaft support bearing. To put a full hard seal in there may doom the bearing to failure.
Edited by DMiller - 15 Jan 2017 at 9:18am
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:57pm
looks like it changes to a 17277
also looks like it might not be available.
you can check with. Applied Industrial Technologies
good luck
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 8:33pm
thanks for the info, are you able to let me know where you came up with the cross reference of 17277 ?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 7:36am
the 17277 crosses to this national #.  does not mean it is correct application,   I have no idea. It is a chicago rawhide to National #
Edited by CAL(KS) - 16 Jan 2017 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 10:58am
I HAVE CROSSED AC NUMBERS TO NEW SEALS AND MOST OF THE TIME HAVE TO DOUBLE THEM UP BECAUSE THERE NOT THE SAME THICKNESS AS THE ORGINAL.
DAN
I.D  1.75''
O.D  2.378
WIDTH    .25''
Edited by Acdiesel - 16 Jan 2017 at 11:00am
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote jchance Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 2:38pm
i contacted minnpar and they gave me the following specs for part number 70620279
OD is 2.56
Width .188
ID 2.167
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 4:30pm
These seals ar for oil cluch shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 5:10pm
Hector, is this a true seal or is it a gland as in a hydraulic cylinder made of rawhide?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:35pm
Yes these 2 seals are true seal  620279 and are instaled on retainer cluch shaft rear bearing and these are in my manual HD11 PAGE 148
