Adding 1.5" grousers to a HD16AC
sdtplus4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Topic: Adding 1.5" grousers to a HD16AC
    Posted: 04 Jan 2017 at 3:49pm
I setting up my HD16 to pull a tile plow can I add anything to my grouser for better traction? Will my finals hold up? Thinking of adding 1.5" weld on grouser
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 10:32pm
How much grouser do you have now? I would not go much over new height.  Depending what size you have now could look for wider grousers as well.
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 5:49am
If you're in the dirt you can go as high as you want . As long as the clearance doesn't hit the fenders or anything else. You're limiting factor is how good of a welder you are and what type of new bar you put on the old pad . Single bar pad I would stay under 4 inches . How wide are the pads now.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 7:39pm
My grousers are around 20" wide  2" tall ,I have been a welder by trade for 25 years. I don't want to tear  anything up,right now it does not grunt at all to spin the tracks. I have a Johnson tile plow it is a pretty good pull sometimes. Would it make much difference between taller grouser v/s wider pads. I have read the final drives can brake on these dozers????
Edited by sdtplus4 - 05 Jan 2017 at 9:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 12:00pm
Power to weight vs traction and overstress
If you are not spinning the tracks now - then why longer grouser length .
Only so much power can be applied before something gives - in many cases the limiting factor is traction - or in the case of my track machines - engine stall.
 If your trying to pull something greater than rating of machine - find another machine to hook on the front .
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 7:56am
Coke, I believe he said he was doing some spinning, but I agree with you, lock her down to the ground too tight and something is going to give, and probably be parts hard to find. So I guess it would depend on how much spinning and the ground being worked if a person wanted to add to the grousers. Running the engine just a little off full power might keep breakage down.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 10:41am
A young tile contractor that I know starting in his own business in the early 80's bought an A-C 21B to pull his tile plow. To everyone amazement, the first thing he did was cut it in half! He then added about 4-5' to the overall length to make the tracks longer. It was a weird looking rig with all that empty space between the cab and the engine. In the field he could plow in tile when no one else could. It was the forrunner of all modern tile plows.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 12:14pm
When I had my dozers  I use some ciment rods  1 inch for the pads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 3:29pm
Thanks for every one's input mud is where I spin most but I realize
that if I add to my grousers it will bit harder.I run at low rpm and try to stay under 1 mph but know I will throttle up if it gets hard to pull.This is also a farm dozer so it will have other tasks as well. I didn't know how robust the finals are I don't think I have ever ran it at full power
ghostriderinthesky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 12:50pm
i have a bundle of ready made weld on grousers i bought many years ago for a D6d cat 24 inch pads i would sell. i also have a full set of tracks for same dozer with new pins and bushings but the rails need to be builtup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:39pm
Where you from,how many and what size and are your weld on grousers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 7:46pm
enough to do a d6d cat with 24 inch pads. bought from cat. they are long sticks of grouser material that have to be cut to lenghth and welded on. they already have the bevel on both sides.   oklahoma
Post Options Post Options   Thanks (0) Thanks(0)   Quote sdtplus4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 9:56am
how tall are they
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 7:47am
pretty sure they are 1.5 inch but they may be 2 inch. i will have to look.
