Allis Chalmers C wide front
JimB View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JimB Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C wide front
    Posted: 03 Jan 2017 at 1:40pm
How hard is it to change a wide front C back to narrow like it was originally?
I inherited a wide front and want to convert it back to original.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 2:04pm
You will need the whole front pedestal.
ALLIS EXPRESS!
This year:
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 2:15pm
Did it come from the factory with NFE? If so, is it possible to contact the prior owner to see if he still has the parts. Probably unlikely, tho.
Here in my part of New York State it seems as many WFEs as NFEs were sold.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 3:30pm
Jim,
I have a pedestal and steering box and drag link for a c if your interested. im in Ohio
John
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 4:41pm
If it has the C wide front, not the B wide front and the front pedestal for the C it is about an hour or less job. After the radiator is removed and the drag link removed at the front you just have the four nuts to remove holding the front to the engine block. Pull the wide front off and slide the narrow front on the studs and tighten the nuts.  That time is assuming you have the proper tools to work with which includes jacks and an engine lift to hold the narrow upright. I have always worked alone but it would help if you had a lifting buddy to hold the narrow up while starting the nuts.
I decided to pull the narrow front off my C and put a narrow front from a CA on a Saturday evening for a Sunday pull.  It took about two hours which included drilling the holes in a block of steel to mount it on the front of the CA front.
Like the picture
This page was generated in 0.112 seconds.
