Adjust clutch pedal |
Sitesstables
Topic: Adjust clutch pedalPosted: 03 Jun 2010 at 6:00am |
Need to now the proper length or how to adjust the cluct pedal on my WD.. As of now it works but is all the way on the foot rest.. need to know how far out it should be from the foot rest..
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 05 Jun 2010 at 7:50pm |
it should not go all the way to the toe plate.there is a protruding stop on the side of the transmission case that stops the pedal before it reaches the toe plate.the deminsion from the stop is 1/2-to 1 inch before it contacts the throwout bearing.a lot of these stops are broken off...
