6080 with 3 piece crank
wlhageman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wlhageman Quote  Post ReplyReply Direct Link To This Post Topic: 6080 with 3 piece crank
    Posted: 28 Dec 2016 at 9:34pm
Bought a 6080 with fWD and cab, Owner said it started knocking and Quit. When loading it was told that the dealer said next time it would need a new crank. Now I'am in search of block and crank, Possibly running engine for the restoration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 10:16pm
If it has the front external thrust bearing cradle set up You should be fine to get a Gleaner F2-F3 engine to replace it.Don't know if later combine engines got the bigger thrust brg like tractors but wouldn't matter with the external thrust. Hope you bought it right.
Edited by SteveM C/IL - 28 Dec 2016 at 10:17pm
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 12:14am
I may have parts or a complete running motor if you're interested
