combine engine
Cb NwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cb NwO Quote  Post ReplyReply Direct Link To This Post Topic: combine engine
    Posted: 02 Jun 2010 at 8:58pm
I'm stickin an e gleaner combine engine in a tractor and can't get it to react to the throttle like it should, I even put the governor off of the tractor in it but still it's either idle or pretty much everything she's got. Any suggestions?
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 9:59am
Did you change the govenor housing also are did you leave the combines on it ? The tractors gov. spring has a wieght in it and the combines doesn't ,just wondering Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cb NwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 12:08pm
changed everything, including the spring. Put a timing cover from a tractor on it so there isn't really much else to change so I'm kind of baffled.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 12:13pm
Take the rod going to the carb throttle off and at front of the engine.  Move the throttle lever to wide open, grap the rod you just unhooked and pull it toward the front of the engine,  is shoud just be able to go back into the hole in the arm, can be just a shade short.  If it wont hook up, the bend the arm until the rod just slides in the hole.  HTH
