Cracked block
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Cracked block
    Posted: 02 Jun 2010 at 8:34pm
The C/B project has a cracked block. Do they typically crack all the way through? Will water get in the oil from the crack? I may weld it up and hope for the best. I know I have saw others comment about cracked blocks in the past. Looking for some advice on what to do. I really do not want to pull the engine. I do not have time for that type of project.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 8:35pm
where's it cracked?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 8:59pm
I mainly deal with junk. Even the heads that dont leak by the time I port them to the point I am after usually do . Like most cylinder head porters working on cast iron I have come to appreciate Belzona 111 supermetal . http://www.belzona.com/assets/PDFs/XXII_13.pdf
Edited by mlpankey - 02 Jun 2010 at 9:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 6:07am
The crack is behind the generator and carb.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 7:48pm
What planky said, bolt a metal patch over the crack, learn how to stitch the crack or you could weld it. If I was to weld it I would have it TIG welded using cast iron as a filler. You can TIG weld it without preheating as long as you go slow enough that an inch away from the weld you are always able to touch with your finger without getting burned. Weld and wait then weld and wait.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 6:55am
The thing about this is someone already tried to repair it and did a horrible job. I wish people would take a little pride in the work they do. I will fix it up and see how it goes.
