Follow up to WD45 Final Pan Request - Pic
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: Follow up to WD45 Final Pan Request - Pic
    Posted: 02 Jun 2010 at 3:18pm
Has anyone ever seen a bull gear tear into the pan? I assume the spacer on the axle would have to fail?? Maybe the pan got hit, a stump or somehting and it got bent into the gear?? Any input here?
1954 WD45 NF "Iron Tater"
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 3:20pm
might want to check the snap ring that holds the gears in place. Might be gone or came off. Had that happen one one I worked on, cut a whole all the way through the pan. Found the snap ring just hangin out on the axle.
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 4:16pm
Might be the nut for the inner bearing of the bull gear is coming loose letting the bull gear move outboard. Pop the cap off the final drive housing and take a look.
Dave
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 8:21pm
I saw it one time and it was a bearing out
