230 gas sleeve
Baldwinm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Topic: 230 gas sleeve
    Posted: 05 Dec 2016 at 9:34pm
Where can I get a single sleeve for a buda 230 gas engine? Just got one to put in a wd45 diesel frame and one cylinder had water in it that left a nice valley in it. Other cylinders look great. Also are there two different types of sleeves that came in these with or without grooves?
Edited by Baldwinm - 05 Dec 2016 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 9:44pm
All WD45 D had the o rings on sleeve. Later 230s had o rings in block.    MACK
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 9:46pm
I have 230 gas piston & sleeves. call 815-238-4506 with dimensions
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 12:10am
I have some used B-230 gas sleeves, they have the O rings in the sleeves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 6:05am
Okay I'll probably be getting a hold of one of you all once I get this sleeve out to see where the grooves are
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 10:55am
I have 1 new early 230 gas sleeve kit that needs a new home. Send me a pm if interested. Thanks matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 9:06pm
My sleeves have no o ring grooves in them. Grooves are in the block. So does anyone have this style with stock bore?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 9:16pm
I have a new sleeve. call 815-238-4506
