WD 45 Rear End Trouble
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Rear End Trouble
    Posted: 31 May 2010 at 9:54pm
I can buy a nice WD 45 for just a $150.00..BUT...the owner says the rear end is locked up on one side. Like anybody else I think its just the brake locked up...UNTIL..I notice there are two differnt size tires on the back...and not just a little off size...4 or 5 inches ...SO...heres where the experts come in...What is the most likely mess here and is it worth fix'n ????
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 11:43pm
For  only $150.00 it would be worth it. You could always part it out and get your money back. If it's just the brake  like you think, then you got yourself one heck of a deal on a good tractor..  John
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 5:25am
Don't know what the trouble is either, but run - don't walk - to close that deal!
WC, CA, D14, WD45
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 5:58am
Buy it! Could be a very simple fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 6:33am
I agree with the "Buy it Now" crowd. Any parts it may need in back are still plentiful.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 6:56am
Spider gears could be locked up in differential. Labor intensive but a used pumpkin should be easy to find if that were the case.
Wink
I am a Russian Bot
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 10:25am
THANKS for the input guys...I am sure something in the rear end is locked or broke...I dont think it is good to have two different size tires on the back...BUT ...I thought since each side is independent for steering MABEY it would be an easy fix...I will go get it and keep my fingers crossed.... I may have parts for sale???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 10:41am
Good for you, Cobb. As said above, there's a very good chance that you can repair whatever is broken/jammed. If not, there are lots of WD45 owners out here who may need a part or two.
WC, CA, D14, WD45
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 8:38pm
pull the brake rotor cover and ck.the brake assy.also ck the rotor and make sure it has not cracked and chunked out locking up the one side.all you have to worry about then is getting the brake shoe anchor pin out...
armandjones82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armandjones82 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:12pm
If you do well in pulling the brake rotors, try to change it to a new one. Brands like roto tech brake and others would be a good thing to have in order to compensate the performance of your vehicle.
Edited by armandjones82 - 28 Jan 2011 at 6:49pm
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:26pm
If it runs well and you part it out, how hard would it be to get the engine to PA? lol
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 9:02pm
If only one side is locked up its most likely the brake. When you break a gear niether side will move a full turn. Its possiable to break a bull gear but very unlikely there pretty tough. I guess If one wheel is good its worth $150 and the rest is free. I would have pulled the money out of my pocket before he was done talking.
Edited by Dakota Dave - 25 Jan 2011 at 9:04pm
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 9:22pm
I could probably buy it drive their and back to get it fix what ever is wrong and come out ahead of buying a good driveable tractor
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 10:06pm
Hey guys ..you took me by suprise...I have'nt been on for a while...I did peel out the $150.00...and found 2 more...the bad news is I needed some money...SO...down the road they went...I did pick up a nice WD45 DIESEL though...If I get back on skid row...that might be for sale....you know how it go'es...One day you think your Howard Hughes...The next..its Sanford and Son....
