B and CA fuel tank interchange (?)
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Topic: B and CA fuel tank interchange (?)
    Posted: 05 Dec 2016 at 12:19pm
The fuel tank on my B has gotten pretty leaky. Has been patched with JB in the past and red-koted, too. Still leaking at anything over 1 gallon or so.
Not sure where to go from here.
Will a tank from a CA fit on my B? Both are from the early to mid 50s.
Any good sources for reproduction tanks (?)
Chris in NE Florida
Jhebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhebel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 12:32pm
CA tank should fit.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 12:38pm
Any B/C/CA gas tank with a strap fastener on the top rear of the tank is a direct replacement any way you go. No Reproductions are being made.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 2:12pm
As long as both tanks have the strap with bolt on the back, the CA tank will fit on your B or C. A B or C tank will NOT fit on a CA becasue the starter switch on a CA needs an indent on the bottom of the tank.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 2:14pm
On a side note, in would be profitable for someone to make plastic or resin replacement tanks becasue I easily get $100 for a used B/C/CA tank on ebay (in great shape)
www.awtractor.com
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 3:13pm
I saved a real bad tank for my C with fiberglass mat. I sanded the tank to bare metal, then cut strips of mat, soaked them in resin on a plastic bag over a plank, laid the strips on the tank tight without over lap. when cured I sanded smooth, then coated with a thin coat of bondo. (I put a small amount of the resin in the bondo mix) I then sanded, primed and painted.  That was about six years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 3:53pm
Jump over to the YT Site, Allis Chalmers in Classified Ads, Pictures.
A fella named Paul in Wentzville, MO parts out the B, C and CA specifically and lists many available parts. Have bought from him previously and he is a straight shooter. Any of his ads (he usually runs many) will have his contact info and this guy deals in plenty of parts.
Tim
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 4:00pm
I'll have a B gas tank shortly if you need one.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 7:51pm
Have a couple that have been cleaned.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 8:14pm
Doesn't the CA tank have a depression in the bottom for clearance of something, can't remember what.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 8:38pm
Starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 7:58am
actually the top mounted hand operated starter switch makes the dent on the bottom of the gas tank necessary on the CA AND late Bs and IBs
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 3:59pm
Starter
kelso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kelso Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2020 at 7:43pm
Does anyone still have a gas tank for a AC model 1949 C ?
Thanks,
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2020 at 9:51am
Thanks,
Tim
Instead of bring up an old thread, go to the classified section and make a new post. You'll probably get a quicker response if anybody has one for sale.
Gafry53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gafry53 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 11:53am
Just bought a model C with leaking tank
how much for tank ??  gafry737677@gmail.com
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 4:04pm
Gafry
Most of this Post is about 4 years old.
I think you would be better off starting a New post in the Classified Section with a Subject
Wanted-Gas Tank for a 'C'
G
