OFF COLOR-Ford 4000
TL12A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12A Quote  Post ReplyReply Direct Link To This Post Topic: OFF COLOR-Ford 4000
    Posted: 24 Nov 2016 at 9:10am
Any ideas why all the power steering fluid gets pumped out the vent in the steering gear box? T.I.A
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 10:34am
I'd guess there's air getting into the system. Does the oil look foamy ??
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 10:41am
Bad seal on the suction side of the pump?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 11:18am
yes  we did a ford 2600 two months ago , seals in the bottom of the orbit motor are bad that is the cheap part the cause of the prob. will the needle bearing in the bottom will be bad so you will probley have to re cover all of the loose needles, also  at least one of the two thrust bearings will be  about shot also the upper steering shaft bushing and seals will need to be replaced,  otherwise the new seals will not last a day ,   hardest part of the job is  getting the wheel off an the cowling off i think we was about 260 .00 in parts for that job
