tell me about the M100B
ghostriderinthesky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Topic: tell me about the M100B
    Posted: 22 Nov 2016 at 2:57pm
I am looking for a different grader than my AD4 and have spotted a M100B. can anyone explain how the blade lift controls work? I an familiar with the AD4 and the old Cat star drive Knuckle busters. is the M100B similar? can the levers be adjusted easily to save my arthritic hands? I don't mind my AD4 so much but am tired of no power steering.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:19pm
Do not take this for gospel truth, but I think the M100 is fully hydraulic. I could be wrong, but I can't find my Allis construction equipment book to verify it. Hope someone else chimes in and sets the record straight. Darrel
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:21pm
I have a M100B they are the knuckle buster controls
Edited by ILGLEANER - 22 Nov 2016 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:27pm
The AD4 I ran had steering assist and it was better than the BD4 but still left something to be desired.I always wondered why a guy couldn't add a Char-Lynn unit in the steering shaft and make it work.....and it seems like Darrel is right about hydraulics on M100.Been a long time since I seen one.
Didn't IL Gleaner get an M100?
...took too long on the post
Edited by SteveM C/IL - 22 Nov 2016 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 9:06pm
I know now the M100B has knuckle buster controls but it also has hydraulic for steering and i think brake booster controls. for those that have them are the blade controls comparable to the old caterpillar controls? i thought about trying to put a Charlyn setup on my AD4 but i think i want to just get a different machine for now.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 4:06am
From my experience with an AC 45 make sure you have a manual if you try adjusting the blade controls.
And if the dog clutches are badly worn you can reverse them and get another go.
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 6:57am
When you do blade adjustments on the m100b, you need to idle down. If you don't you'll find out why they call them knucklebuster controls. Don't ask me how I know.
Ya cain't fix stupid.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:43am
yes, same way on my 145T.  blade controls work better when not running full throttle but power steering sucks when idled down
