Painting rims without having to touch up paint
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: Painting rims without having to touch up paint
    Posted: 10 Nov 2016 at 11:38pm
 I just wanted to sure how I paint my rims without having to touch up the paint.
1st I clean and prime the rim and let dry.
2nd I mount the tire and install the tube.
3rd I use a 16" coulter and trace it on two pieces of cardboard. The center of the coulter must be offset on to the cardboard so you can overlap later.
4th I cut the cardboard on the traced line.
5th I slide the cardboard between the rim and the tire. Make sure that the valve stem is in the tire not in the pulled though the rim. Best to do the back side of the rim first.
6th Paint rim
7th Pull out the cardboard. flip the tire and rim over and lay the tire on two blocks so that the rim does not touch the floor. Repeat step 5 and 6.  Pull out cardboard.
8th let paint dry over night.
9th Pull valve stem though hole in rim and inflate.
Thanks & God Bless
Dennis
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 12:00am
Hey! Now that's a good idea!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 2:39am
very nice! now....about the rest of the combine.....
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 4:52am
Excellent idea.  I could have used that trick a couple days ago!  Now I'm having to touch up scratches.  Thank you.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 7:20am
Very clever. Can I remember that ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 7:55am
 All in do time Shameless.
Thanks & God Bless
Dennis
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 8:11am
Now that's thinking. Great idea!!   It certainly will get used in my shop. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 2:32pm
Shameless will have to give that idea to his wife
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 6:51pm
Clap nice thinkingClap
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 8:18pm
Are we planning on putting this into the "Knowledge Base" ??
GREAT idea.....
