C water pump seal/bearing
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: C water pump seal/bearing
    Posted: 10 Nov 2016 at 7:01am
I should probably knock on wood, shut up about it but here I go.
As far as I know, the water pump on my 1948 C is the original.
I doesn't leak a drop, the seal and bearing is still good. Is that possible? Did they have the best ever seals in '48? Comparing to stuff from the '70's and on it seems like a miracle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 8:39am
Lots of things still work pretty good on these old tractors. I am surprised at how they keep going with little maintenance in some areas. I haven't answered your question. But if its not broke don't fix it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 9:00am
just put a pump on WD.Been on there at least since1962
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 10:20am
Just did one on my CA. I've owned it 20 years...
