I600 Rear Axle??? |
Rib Lake Allis
Joined: 01 Mar 2012 Location: Rib Lake, WI Points: 59 |
Topic: I600 Rear Axle???Posted: 08 Nov 2016 at 8:53pm |
I'm replacing the brakes on my I600 and there is a bushing on the axle shaft near the brake drum. That bushing is worn about 3/16"-1/4" on the top side. What could cause this? The bearings apear to be good. Any help is appreciated Thanks Steve.
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 998 |
Posted: 09 Nov 2016 at 4:17pm |
Maybe post a picture and that might help...unless someone in the past has put some kind of speedy sleeve for the seal there isn't supposed to be a bushing there on the shaft. You say worn on the top?? When the shaft turns any wear should be the same all around?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54694 |
Posted: 09 Nov 2016 at 6:26pm |
Could've been something someone added, through the years, or it had bad bearings, once that were replaced, before you got it. I'd get a look at the exploded parts diagram, to see if its an added part...
Rib Lake Allis
Posted: 09 Nov 2016 at 7:18pm |
After looking at it again today I see that it isn't a bushing. But it still puzzles me why that hole is oblonged.
