WD and WD45 LPG tractors
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: WD and WD45 LPG tractors
    Posted: 05 Nov 2016 at 1:55pm
I just got time to get the 45 running, only needed points and a condenser, so I thought I'd take a picture of both of them. The WD is a 1952, the 45 is a 1956 and has factory power steering. They both run on both gasoline or lpg and we're both running on lpg in the pictures. The WD's never came out on lpg but AC sold a kit so you could retrofit them. An engine kit was included in the kit as you needed higher compression pistons to burn the lpg.
Edited by Michael Crowe - 05 Nov 2016 at 1:57pm
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 6:45pm
Now that's a pair to draw to! With all the LPG tractors you have now might think about a LPG storage tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 7:20pm
Don, that's the most important part of having lpg tractors. I took a tank up to the propnane dealer last year and he got me new valves and a bulk tank with the wet line and hose to fill up the tractor tank. I really like how quiet they run on lpg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 7:42pm
Very nice pair of unique Allis tractors! Thanks for posting the pictures!
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 8:35pm
I really like the LP tractors,, I got 2 WD-45's, 2- 44 special MH, and a 730 JD all LP,,,well, the 2 45's are dual fuel..
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:23pm
      Good pictures Michael.      Duane
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:48pm
I've got a good friend that he and his brother have almost everything on LPG. D17 series 2, MM GB, WD-45 with dealer add-on (replaces gas tank) WD45 with factory propane, and a slew of others!
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 6:12am
Good looking pair Michael. That is one I don't have yet. Yet!
Ray W.
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:50pm
I've got their twin - triplet?  Haven't run it much on gasoline, it runs really well on LP.  I just mowed about 5 acres with it this weekend.
With the short shelf life of the current gasoline, I like propane more and more.  Besides the WD, I've got a D19 and 190.  Thinking about going that way with a B and a G at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 9:04am
Did the WD ever come from the factory as a dual fuel tractor, or is that a conversion using WD45 parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 1:09pm
Ted, WD's never came from ALlis in the lpg fuel version. I had a sales price book and it showed the kit to retrofit a WD but it is different that the 45 system in that the carburetor is different and has a different part number ( the key external difference is the air intake port is the WD size of 1 1/4" instead of the larger 45 size) and Included in the kit was an engine rebuild sleeves/pistons as you had to install the higher compression pistons to burn the lpg fuel. My WD in the picture has a nos dual fuel carb with the correct part number disc that I was lucky to get from a forum member.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 8:22pm
WOW Michael, you have a couple of gems!!  I'm not jealous though........well, maybe a little.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 8:50pm
a couple of good looking old tractors Michael....gonna have them painted up before Boonville?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 7:20pm
I won't be painting any tractors until I learn how to do it, which will be many years done the road.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2016 at 7:23pm
Those are REALLY cool tractors!  Thanks for the pics!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
This page was generated in 0.621 seconds.
