7020 power shift noise |
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Topic: 7020 power shift noisePosted: 31 Oct 2016 at 8:19pm |
I've noticed it right since I've had the tractor, the forth power shift in high and low range has a gear noise not loud or rough sounding just can hear it more so than the other speeds. Just curious if I should be splitting it and looking into the planetary gears or is it normal for its age. It has 7522 hours on it. My dad wonders if it was a gear that was used a lot. Any opinions are appreciated, thanks
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
MACK
Posted: 31 Oct 2016 at 9:14pm |
A PS is noisy in all gears. Probably is ok. Take the floor out and drive it around and see if it is worse in that speed. MACK
DrAllis
Posted: 31 Oct 2016 at 9:24pm |
New rubber cab mounts.
WD45Diesel57
Posted: 31 Oct 2016 at 9:32pm |
Are new rubber mounts still available from agco?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 31 Oct 2016 at 10:54pm |
Probaly....how many "arm & legs" you got to spare |
