Problem w/Spout motor/620-FIXED!
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: Problem w/Spout motor/620-FIXED!
    Posted: 23 Oct 2016 at 1:32pm
Now that I have the toggle switch wired, I have a problem with the spout motor.  All new wire up to connection with blower motor lead.
I started with a 10 amp fuse, kept blowing, went to 20 amp, kept blowing, went to a 25 amp in order for motor to run without blowing fuse. (Motor gets hot, wires get warm when using the 25 amp. fuse.)
Have put new female spade terminals on wires to motor, cleaned up the spade terminals on motor as best I could using emery cloth wrapped around a screwdriver.  All connections appear good.
Took blower motor apart. Put 3 in 1 oil on bearings, cleaned up inside of motor, brushes look like they still have life in them.
Motor acts no different if mounted to gear on spout control, or running without any load.
Motor runs faster in one direction than the other.
I'm not really very electrical versed, but feel there is a problem somewhere.
Any ideas?
UPDATE =
Late Oct., put a different chute motor on from salvage yard - hooked it up with blower  just sitting on the floor-worked PERFECTLY!
NOW- 11/25/16- Mounted blower on tractor, (after mounting a NEW mini alternator that DOES NOT WORK) figured that if the buyer ever sends me a working alternator, at least I will have my "new to me" snowblower on already.
NOW - Chute motor doesn't work! Has 12 volt + power all the way to motor - on both sides of the toggle direction. Changed motor as I also purchased a new motor. Doesn't work. Ran a ground from motor itself to negative post on battery. Nothing!
I think I am cursed with this blower/chute/ mini-alternator project!
WHAT THE HECK AM I MISSING?
Thanks.  Merle
Edited by macvette - 26 Nov 2016 at 7:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 4:46pm
what is voltage of motor ? what type of connection between load and motor ?
If it's a DC motor and low voltage - look for armature moving over inside field windings and dragging - a off center movement will cause drag and high amperage draw .
 Find this real often on starter motors after a couple years of use .
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:49am
12 volt with spade terminal connections. Believe it's like a GM windshield wiper motor.
Plastic gear between spiral gear on motor and blower chute control.  No rust - turns freely.
No difference in motor performance whether it has load, or running free.
Thanks.
Edited by macvette - 24 Oct 2016 at 10:21am
wiplowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wiplowboy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 4:10pm
I just did one on sunstar. Try running a ground wire to tractor. Will try and call you later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 7:27pm
Yep, ran the ground wire before got everything else wired up.  Person that sold me the blower told me about running the ground wire with a disconnect direct to tractor, as he also said that is often a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:35pm
OK.. I'm cornfused.... EVERY permanent magnet DC motor I've ever come across does NOT need a 'ground' wire. You simply wire up to a DPDT switch to 'flip' the power going to the motor leads.
So can someone explain  the 'ground wire' comments.
As to the heating up comments, yeesh.... 12 volts, 20+ amps is over 240 watts ! Think 4 - 60 watt light bulbs !! Yup a LOT of power,far more than needed to turn a spout, me thinks.... Anyone got part numbers so I can Goggle specs ??
Jay
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 8:08am
When bench testing you need that ground.
Dusty
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 9:18pm
its actually a rear window motor from a 80's jeep wagoner,i bought a spare for mine and it matched up perfectly,still have it don't use blower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 6:18am
dusty ... why ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 9:08am
Thanks guys for the info. I finally broke down yesterday and ordered a window motor off eBay. Hopefully the end of the problem!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:59am
Merle,
How did you make out with your spout motor delema?
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 9:17am
Great! Pulled a window motor from salvage yard Buick, Works perfectly. No more hot wires, or 25 amp fuse!
Now just waiting for a fellow website member to get a stubshaft built for me to mount a mini alternator, then I will be golden.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 12:21pm
Cool! What kinda Buick? Wagon or something? I'm gonna need one for mine to I think. Its not responding. Humming a little, but not responding. LOL! Did ya havta' make any alterations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 5:59pm
Buick Regal, I believe.  You can look on the "discount auto parts" site, and just look at the window motor that looks like the same mount that we have, and it will give you quite a number of years/make/model that this  motor fits.  It will be left front or left rear window motor.  Just grab the pigtail from the switch to motor at the same time if you grab one out of a salvage yard.  I checked with a local autoparts supplier to get the pigtail to motor wire if I got a new motor = $35.00!  My $20.00 pull it myself used unit was a much better deal.
I did have to drill 2 new holes in mounting bracket (one hole matched) and cut 3 pieces of tubing 1/2" long to place between the motor and bracket as spacers.
Works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 7:37pm
using a jeep regulator like I mentioned above, u don't need to modify or drill anything...isn't anyone listening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2016 at 10:43pm
I didn't have access to a jeep motor at the time.  Nothing that old in the salvage yard.
For the 20.00 it cost me, and the ability to drill 2 holes, I feel quite comfortable with my solution, and it works perfectly.
Edited by macvette - 04 Nov 2016 at 10:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 10:21am
Yup! We're listening. Its always nice to have another avenue to go up just in case the Jeep motor wasn't in reach. That just happen to be the case for Merle, so he found somethin' else that would work. Thank you for the info Doug! Its appreciated. For me, I don't have time to run in a bone yard, so it would actually be cheaper for me to purchase one off of e-bay or an auto parts store. The $35. bucks to me isn't bad. My time is worth more than that with what I have goin' on in my life....   LOL!
Steve@B&B
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 5:17pm
Steve, I think it is $35 for the pigtail, not the motor which is not such a bargain. When I was looking 10 years ago, new motors were very pricey. There are many applications of the motor to look for used. I think I printed them out and may be in my 720 binder. I do remember off the top of my head, that it was many GM products power windows.  I'll look and post, hope this helps, Trev.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2016 at 6:28pm
Yep, the pigtail to go to the motor was $35.00 from NAPA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2016 at 9:51pm
Please see the update added on to bottom of the thread I started this with - still in trouble!
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 5:07am
I bought new GM motor don't remember #'s but bolted right up and works fine was $75 new though
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 8:24am
Mounted my new GM motor before I UPDATED this thread. Doesn't work either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 7:25pm
GOT CHUTE MOTOR WORKING!!!  So very happy!  Now to get a mini alternator that works, and I will be golden!   LOL!
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 1:51am
So you're not going to tell us what the issue was?
GB :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 9:56am
Absolutely no idea why it worked perfectly just sitting on the floor hooked up plus  a ground wire from tractor to blower, but not when mounted on tractor.
When I pulled all my wires out of the loom, and went to rewire everything from the battery to toggle to blower, think I found the answer.  I originally posted this problem on a number of the forums I belong to, and another member sent me a factory printed toggle wiring diagram he was sent when he got a new 2 wire  motor, and that is what I used to wire.  On the 26th, a forum member from another forum I was posting on sent me a printed diagram for the toggle wiring. GUESS WHAT - IT WAS DIFFERENT!  Wired toggle according to the just received diagram, and it works perfectly!
Obviously, not all these little  motors are wired the same!
No matter - I am still very happy with the final result!  Hoooooooray!
Edited by macvette - 29 Nov 2016 at 10:00am
