185 rear wheel weights
ChrisS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Topic: 185 rear wheel weights
    Posted: 06 Oct 2016 at 3:37pm
Anybody have any pictures they could post of the factory correct rear wheel weights for a 185 with 28" spin out wheels.  Do they have a part # or casting # that is cast into them?
Are there different diameter weights depending on wheel diameter or is it a one size fits all 185's?  Also what do they weigh and how many can you put on or should put on.
Thanx,  Chris
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 3:47pm
If you look in the knowledge based section there is a list. Am4483-1 is the correct weight. Takes 4 per wheel
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 11:30pm
30" and 38" wheels take a one piece weight.
ALLIS EXPRESS!
This year:
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 5:50am
Not sure in this case? but sometimes it makes a difference if early or late. This is our early 185 on 18.4-28 and what I believe are prim and proper front and rear weights.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 5:58am
Butch those pie weights are what I have ony d17. Don't know if they didn't make them for long or if people just don't sell them but I think they are pretty hard to come by. The one peice weights like the wd has are much more common and can be stacked to get the same weight.
scott in tenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 7:59am
I have the one piece one my 185 with 28 inch rims. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 8:55am
Eldon, are you saying that the style of weights in your picture will not fit with a 28" rim?  Do have a casting # and a weight / lbs of those style of weights?
I'm looking at a set of weights the seller say's came off a D17 and said they will fit a 185.  They look almost identical to the casting #AM2795-10 shown in the knowledge section link. I realize these may not be factory correct but would the fit / work?
Also how much weight can you put on the back of a 185 before things start to break?
Thanx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 8:59am
I don't think you can put enough steal weights to break things. The pie weights are 150 per wheel. This is nothing compared to what you get when you load the tires.
Or put another way like having your two teenage boys one on each fender as you drive out to the hay field...
Edited by Dan73 - 07 Oct 2016 at 9:01am
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 9:11am
I have the same exact one piece rear wheel weights that Eldon has on the tractor in the pic and they are on 28" wheels and fit right. Might have a different casting number though, if there are two different sizes.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 9:21am
180-185 pie weights are 75 lbs each or 300 pounds per wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 9:23am
Dope stupid me yes 4 per side not 2....
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 9:37am
Going from Memory, there is a maximum weight the manual says to put on a 185 by 28", 30", and 38" tire size. My Memory says it was something like 9100, with 30" and 9400 with 28". 38" was a lot less, something like 8000. There's sticker on mine for max weight with 30" tires.
I figured up my 185 weight with loaded 18.4-28 tires and front weight rack to be right a little under the weight limit. You'd have to really try to get overweight with the 28" tires like load them with fluid and stack on a bunch of weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 10:10am
They are probably the same, I never tried them on a 28" as I have lots of pie weights. I know the pie weights will not fit on a 30" rim, the centers have a different profile.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 10:11am
My 185 has a decal showing max weight, guess they were serious about it!
ALLIS EXPRESS!
This year:
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 10:29am
So, the 185 came with both, the pie weights and the one piece weights then? Anyone know how much one of the one piece weights weigh? Say that real fast three times! LOL!  I have two one piece weights on each side, plus a full rack of weights and also have the rear tires loaded. It was that way when I got it...28" tires.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 11:29pm
Butch I believe you are correct. The on-line Agco parts book shows that 185's prior to S/N 12800 used 4ea pie weights per wheel and a 185 S/N 12800 and up used the one piece doughnut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 10:45am
checked my manual.
9400lbs 28"
9000 30"
8000 38"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 10:42am
Rick, Scott in Tenn,
Are your 28" rims power adjust / spin outs???  Do the one piece / doughnut weights interfere or ride on the power adjust mechanism on the rims??
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 11:02am
My rims are power adjust and the weights do not interfere with the shift rail. HTH.      Scott
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 11:07am
Chris...My rims are power adjust and are 28". No, there is no interference with the power adjust mechanisms at all with those one piece weights and are not in any way...in the way! LOL! The number on the weights I have is: 256687  02-WA         Rick
Edited by Rick - 11 Oct 2016 at 11:07am
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 11:10am
So...that also tells me that the weights in Eldon's picture will also fit the 28", 30" and 38" wheels then. Mine are exactly like those.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 11:58am
Eldon,
Do you have the casting number and the weight of the single / doughnut ??
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2016 at 12:07pm
I'd say they weigh around 140-150 lbs. each. They're heavy. Could be that there are different numbers on them, but mine look exactly like the ones Eldon has. Should be the same number that I posted...maybe.   LOL!   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 11:15am
In the knowledge base section the picture of the pie / sectional rear weights for a 185, casting # AM4483-1 appears to have came from a 28" wheel. Will these particular weights fit other size wheels or do they only fit a 28" ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:01pm
I think (and can't prove it, but I think) the sectional pie weights will fit both 28" and 30" wheels. Not the 38" wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:08pm
They will fit (cause there is a bolt hole there), but do not conform to the wheel profile and look goofy....same with the 38" centers.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:34pm
Note the weight bolt hole pattern and the PAW wedge positions....this is why the pie weights will not work on a 30" center. If you look at Butch's pic of the pie weight on 28" wheels you will see that they are centered between the wedges.
Edited by Eldon (WA) - 13 Oct 2016 at 3:52pm
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:37pm
Will fit on 38" centers, but cover up the wheel lugs....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:46pm
If you are not picky and don't want to cover up your lug bolts you can mount them like this, I guess....that is the way this one came on a 185 that I bought.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 5:38am
Other than man-handling them on and off is there any advantage / disadvantage of the single doughnut versus the 4 pie weights?? From what I can glean off the previous posts the max weight you could achieve with the pie weights is 300# per wheel where as with the single doughnuts you could keep stacking them till you ran out of bolt length. Looks like Eldon has 3 doughnuts stacked together. At 140#-150# each that's approx. 435# per wheel.
