Series 2 vs. Series 3 flex head
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Topic: Series 2 vs. Series 3 flex head
    Posted: 30 Sep 2016 at 5:59am
My LM315 has pretty much bit the dust, would like to find a 320 to put on it, but the only head I've been able to find in the greater central ohio is another 15 foot head, but I'm pretty sure it's a series 2. Few questions, will I have to change anything for my auto header hight? Isn't a series 2 just a Hart-Carter flex cutterbar? How much more will I be disappointed in stepping down? I pretty much just need a head to do another 190 acres of beans, then I'll hunt for a replacement this winter. Only have about 20 acres with hills to worry about
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 6:44am
As far as I know a Series 2 isn't a flex head at all but a floating head. A floating head was good for it's day but a flex won't shatter as many beans. IMO I think you'd be disappointed going back to a floating head.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:28pm
That's what I was afraid of. Found a 15 ft series 2 close, and possibly a 20 ft series 2, but I'd have to go to at least 4 hours to see a series 3 on a dealer lot
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:31pm
The series 2 head uses a Hart-Carter flex bar.  The head was not designed to be a flex and consequently not very good in that role.  The H-C flex bar cannot get as close to the ground as the later models.  The Series 3 on the other hand was designed as a flex head and works much better at getting beans into the combine.
