Allis B - aftermarket rockers?
00transamnh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Topic: Allis B - aftermarket rockers?
    Posted: 15 Sep 2016 at 12:27pm
Hey Folks,
I'm new to the forum and have done a lot of 'googling' on the subject but I can not find what I am looking for.
I have a 1940 Model B that I am restoring for my grandfather and in the process of rebuilding the engine have discovered that the rocker shaft and rockers are toast. Does anyone make a reproduction or aftermarket alternative to these assemblies? Am I stuck gambling with used EBAY parts?
Any help would be greatly appreciated.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 12:38pm
No aftermarket made. But there are plenty of trusted vendors here on the forum that will sell you the parts and stand behind them.
877-378-6543
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 2:22pm
Used USEABLE rocker arm assemblies are quite plentiful. Post a Wanted in the classified section of this forum and see what pops up from individuals with a stash of used engine parts.
I will have a look see myself in my stash of stuff.   Ken
Call Jim D for sure.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 6:49pm
I thought I saw an after market rocker set in the pulling section a while back. I believe they were blue and not terribly expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:19pm
Plus 1 on what Jim D said. He and the other vendors on this Forum stand behind their parts. I have never had a problem with anything I bought from him. And welcome to the Forum, you will be able to get a lot good information ans assistance on here.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 9:09pm
oootransamnh....have a c for sale complete 4 brand new tires good tin.getting to old to fool with it.j.w.freck 903-930-1387
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00transamnh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 9:16am
Jim hooked me up with a used set. Thanks guys.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 9:44am
I turned a new rocker arm shaft for my MF-135 on my metal lathe and cut 7/16 threads in the ends to plug them with steel set screws instead of corks that will eventually rot and wreck the rocker arms. Then I had a machine shop grind to the final diameter with a better finish than the turning. The bushings in the rocker arms were steel backed and badly worn from running dry. I couldn't buy them so I bought solid bronze and bored to fit and pressed them in. At the time I did that Central Tractor offered rebuilt rocker arms and shaft.
Gerald J.
