CA Parts Catalog |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: CA Parts CatalogPosted: 13 Sep 2016 at 6:52am |
Does anyone have access to the CA parts Catalog?
I'm looking to see what rear tire/wheel options were available through 1957 |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 13 Sep 2016 at 7:05am |
Power adjust rims were the norm. I too am curious what the book says about optional rim widths. I would imagin they would cover the CA high crop cane version option wheels and rims in the parts book
Charlie175
Posted: 13 Sep 2016 at 7:11am |
I'm running 11.2x24 now. My club will allow 1 size up. So that would be 12.4? or 13.6?
I don't want to spend the $50 on a parts catalog only to find out it lists 10x24 only.... |
Charlie
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 13 Sep 2016 at 7:23am |
I'd be interested to see a list too. Dad said he used the CA one spring and took it in to have 13-24's(14.9 in todays size) put on it. They were still on it when I got it from him. He said the original tires let it sink too much when trying to disc plowed ground.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5163 |
Posted: 13 Sep 2016 at 7:34am |
The parts book only lists the standard PAW rim assembly. No size given (although it's a 10X24 rim) The tire size is listed as 10-24 (new size 11.2X24), so one size bigger is 12.4X24. I have some 12.4X24 tires here if you'd like to come take a look. I went through the same thing many years ago. I do know that a "cane" tractor had 36" rear rims welded onto the standard 24" rim and I think that the tire size was either a 9.5X36 or
11.2X36. I was never able to find any printed documentation. I was able to get the local club at that time to OK the listing from the D10/12
specs to allow me to run the 36" tires. I also have that set of rims available.
Charlie175
Posted: 13 Sep 2016 at 7:49am |
Agco parts only lists the 10x24 rim.
Charlie
Ken in Texas
Posted: 13 Sep 2016 at 8:19am |
Running anything bigger than a 12.4 on a 10 inch rim is pushing it. I went with 11 inch rims running 13.6 rubber on my CA. That is the same combination rim and tire that came on my MF 1260 compact new.
