B12 key
A-Cvtx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Topic: B12 key
    Posted: 03 Sep 2016 at 7:10am
Need a key for B12 if you have one lying around. Local stealers want a fortune for one. TIA
Insanity is relative. All of my relatives are crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 10:24am
can't believe it's 'special'...my B112 uses a regular Indak stamped key as on millions of riders...
jay
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 1:52pm
May take a bit of time, but you may want to take the ignition switch out, and take to local locksmith.  They can cut a key to fit quite easily.  Was fairly reasonable.
 I had to do that with my B-112.  I believe a lot of these older tractors still had a regular ignition key, not the Indak that many garden tractors, and full size tractors went to.
Matt Tallant View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 3:05pm
I have a NOS key for sale if interested.The B-12 has a different key than the B-112.
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 4:49pm
My BIG-TEN has the original "BRIGGS & STRATON key. and I can get a new one cut at the hwd store for $1.85
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 5:03am
Maybe you could make some copies and sell them then. I know I could use 1 for my B110. Key is broken off inside the switch but still works using my thumbnail to turn off/on. Decided not to mess with it unless I found another switch or at least another key before I try to dig the broken piece out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:04am
you can buy B&S keys( aka Indak) from any small engine shop or online in qtys of 1, 10 or 50....I have a drawer full of them from 'dead riders'.Now IF it's 'special', please post a picture  or link.....but all B&S keys/Indak are the same as far as I know.
Jay
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 3:12pm
Push button start tractors used a cut B&S key, which would fit early B-110, and all of the round hoods. Anything newer than that would use the indak key.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 9:49pm
Years ago, Briggs and Stratton was in the business of supplying the automotive industry with "lock and cylinders." There are all kinds of B&S key's out there for antique vehicles. Dad's 1976 boat has a B&S key very similar to the one on my AC Homesteader 8 and early B-Series.
