7040 hydraulics
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: 7040 hydraulics
    Posted: 31 Aug 2016 at 10:35pm
I have a 7040 PD without the 3 hydraulic pumps (they were gone when i got it). Has anyone used a single pump, or different setup?
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 10:34pm
Pump #1 is the gerotor pump and makes the transmission clutch and brake work. Pump #2 is for the power steering, rear end lubrication and charging of the main pump. It is also a structural component of pump #1. Pump #3 is the main hydraulic pump and also provides for the power brakes. I suppose you could mount a double-pump on the engine (there's not a place to do that without engine changes) and you'd have to figure out how to provide 15 GPM to the transmission circuit and then 5 GPM to the power steering circuit, etc. Remember each circuit draws oil from a different reservoir, and then there's a matter of plumbing this new system. Just find the correct hydraulic pump that bolts right into place and works like it's intended to.
This page was generated in 0.097 seconds.
