No start B
telephoneman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote telephoneman Quote  Post ReplyReply Direct Link To This Post Topic: No start B
    Posted: 29 Aug 2016 at 1:44pm
In my never ending problem with starting my B I looked at compression results again. Cyl 1-3 70 lbs. #4-0 .Pulled valve cover,last Valve (#4) is stuck open.Could this be why I can't get gas from carb to engine?
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 7:02pm
No because the last valve is an exhaust valve. Maybe you have a leak between the intake and exhaust part of the manifold, that would do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote telephoneman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 3:25pm
Pulled the manifold today,no leaks.
This page was generated in 0.037 seconds.
