AC 7000 Engine turbo charger
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Topic: AC 7000 Engine turbo charger
    Posted: 08 Aug 2016 at 11:05am
We recently purchased an HD6AG with the 7000 engine. The turbo housing is used up. AC part number is 4359134 for the entire turbo. It does cross to an AiResearch P/N 600590-2. This is the same turbo as the 7G crawler loader. Part number from the existing turbo is a TRW 376B70. Turbo elbow is a 74338108, same as 7G. Any assistance in finding these items would be appreciated. Thanks.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2016 at 5:40pm
Allis Chalmers used more than one turbo on the 7000 motor. My manuals call for Thomson (TRW 370) another manual calls for 317 series. There are several manufacturers that make turbochargers that fit and will work. The basic size of the turbo is T04B each size can have multiple trims (fine tuning for specific performance conditions) Tractorpartsasap on eBay (866) 609 1260 has a turbo for the 7000 motor for $283.85 He may ask you for some measurements that will determine the trim. He may be able to sell you the worn out internals. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 8:29am
Thank You. I read a statement last night regarding replacement of the Thompson/TRW turbo with alternate manufacturers' turbos. That is the direction we are going.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 12:52pm
I ordered the replacement from All State Ag Parts this morning. From what I can determine from the dimensions it should replace the
Thompson/TRW.
Curt Anderson
HD6AG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6AG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2016 at 8:29pm
Hi Ages Cat,
I am curious what brand and model of turbo they supplied you with as I may need to replace the turbo on one of my HD6AG's.
Thanks,
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 11:13am
Andy: When it arrives, and I will post all of the product information.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 5:58pm
I am wondering why you didn't order it from tractorpartsasap on eBay.
They are the same company as All State Ag Parts. The price on eBay including shipping is about $60 less expensive. Please note the number of oem part numbers one of there turbo's replace. Trim numbers are not very important on heavy equipment. Trim numbers are optimized on performance motors where spool up time is important. Heavy equipment motors have a small RPM range so the remaining problems are related to over pressuring and over and over fueling which is a function of size not trim.
It is never too late to learn so if someone has a different experience than me, please reply I always like to learn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 7:48am
Dozer: I did not find the referenced turbo on EBAY that you mentioned. I called the number that you provided and I now have the turbo. It appears to be 100% correct. Thank you.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 9:27pm
HD6AG: The All State AG part number of the turbo is 100543. They also list the  AC/ Gleaner number as a 74009171. The new turbo is identical to inlet/outlet size and clocking of the outlet into the  intake manifold. This appears to be the one. The outlet elbow which the aspirator connects to is burned out as well. We will either build an elbow or use an aftermarket elbow and modify it. The oil inlet/outlets are also tapped with pipe thread as the TRW unit was. No adapter plates are needed.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6AG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2016 at 9:54pm
Thanks Ages Cat for the part numbers,
You will also have to post a picture of the unit once you have it installed because I am curious what goes between the exhaust side of the turbo and the exhaust elbow on your machine.  My parts book shows nothing.  As such, on one of mine, we fabricated a spacer ring to fill the gap and then used a clamp with some u shaped flanges to hold everything together.  I know it isn't right but it seems to work okay.
Thanks,
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 5:20am
The turbo on my 7G still sings up a storm but I am certain it is on borrowed time.  I too will have to manufacture the trim for exhaust as the elbow behind mine is eroded heavily and leaks considerably at the flange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2016 at 11:59am
There are four bolt holes on the turbo flange. I did order a 90 degree exhaust elbow which has four bolt holes as well. One of the illustrations shows a gasket in between. The two flanges need to be secured to/connected to one another-no doubt.
Curt Anderson
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 6:53pm
some N5 combines used the same turbo
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 8:44pm
I know back in the 80s my dad had a 7gb and the turbo went out he got a new one from a john deer farm dealer for about half the cost from getting one from the fiat allis dealer
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 8:47pm
That was back when greyhound or trailways bus was the way parts came in if the local dealer didnt have the parts in stock everything was COD
This page was generated in 0.336 seconds.
