190 cab
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 190 cab
    Posted: 04 Aug 2016 at 5:40pm
Any idea how much a cab like this weighs?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 6:52am
No ideas?
Guesses?
500 lbs? 1000?
I need to drop 1,000 lbs but I don't think it weighs that much.
Charlie
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 7:08am
800-1200 lbs. if has a roll bar inside, 1500 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 7:19am
No rollbar. They were prior to ROPS
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2016 at 7:38am
If I had to guess I'd say less than 1000 and that cab isn't ROPS.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2016 at 10:03am
Not much Charlie as I cut that exact Stolper off my SIII by myself. Removed the glass, light boxes, unbolted door and any panels including rear swing out before cutting the "posts" about mid-way and removed the top portion with a pulley and some rope.
I'd say 500-600 lbs., tops.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 7:39am
Thanks Tim
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 7:41am
I'm at 8900 with me on it and CAB.
I have removed lift arms, which were 200 lbs but really don't have anything else to remove. How are they getting a 190xt below 8000?
Mine has the 3.25" axles so I guess they are heavier.
As is the spin out rims and cast center. I guess I need to source light weight rims :(
Charlie
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 7:46am
the dedicated pullers remove the rockshaft housing and put on a plate
Edited by CAL(KS) - 09 Aug 2016 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 8:37am
Ok. Still need to use mine so oh well....
Charlie
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 2:30pm
Yeah, but Charlie, doesn't know you could lift 4 suitcase weights with one hand.  I don't mess with Tim!!  WinkWink  How do you think we loaded a dead 7045, and a dead 7020??  Tim was pushing!!!  That's how. LOLLOL
Still in use:
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 2:47pm
Still heave the cast rear wheel centers? Go with steel hubs and lightweight 9 bolt rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 8:34pm
Gary, got some for me?
Big smile
Charlie
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 8:39pm
If the deal falls through, I have a set of 9bolt hubs and 18.4-38s that will work. They are spoken for pending payment as of now.
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 8:45pm
Talk to Kenny Sr. at Louderback in Stanley. They had their XT pulling at 7000 pounds before they sold it. Of course this was in the late 80s.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 4:09am
I talk to Kenny every so often. He is pulling a 185 6200 lb LS tractor now.
The 190 is in many pieces with a lot of them missing.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 6:30am
Big smile
I might on the White 2-70 parts tractor I'll check the axle size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 11:04am
Anthony, I'm still holding those pieces that were salvageable off that Stolper for you but no longer travel for business.
As for my size, I'm still working on becoming "round"!
Let me know if you ever have someone coming even close to me as I can meet them with the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 5:38pm
Hmm.  Well, if they aren't in your way, hang on to them, the family and I are thinking of making a round robin tour of TX, to see some of our family down there, and a trip to Hard Eight does sound good.........
Still in use:
This page was generated in 0.681 seconds.
