D-Series Dipstick
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Dana Hobson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana Hobson Quote  Post ReplyReply Direct Link To This Post Topic: D-Series Dipstick
    Posted: 03 Aug 2016 at 5:47pm
What is the proper method for measuring the hydraulic oil level in the D-Series and 100 Series tractors.  Do you unscrew the dipstick, wipe it and then re-screw it back in, unscrew it again and read it??  Or, do you unscrew it, wipe it, then insert it to the threads, pull it back out and read it??  I haven't found any place in any of the D-series manuals that tells the proper way.  I suppose that I am so old that with all the screwing, unscrewing, inserting and then pulling it out I am just confused !!!
If I made you chuckle, good !!  But I am looking for a straight answer.
Thanks,
Dana Hobson
Perry, OK
Dana Hobson
Perry, OK
B,WD-45,D-10,D-12,D-14,D-15,D-17,D-19,D-21,200,7060, HD11E,Gleaner L2
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 7:55pm
I have always just stuck it back in and pulled it out to read it. All that screwing seemed like too much work to me and I alway figured a little extra oil was probably better then too little. If you over fill the power direct clutch pack it will puke out and didn't seem to hurt anything... not that I would ever over fill anything.
This page was generated in 0.079 seconds.
