WD45 governor thrust bearing
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Topic: WD45 governor thrust bearing
    Posted: 13 Jul 2016 at 3:50pm
I am looking for the measurements of the governor thrust bearing on a WD45. I need inside, outside diameters and the width of the bearing. Apparently this bearing is not available at any of the standard bearing locations but with the proper measurements, I may be able to locate from a different supplier.
I will keep the Forum informed if I find a source of new ones. I have located a few good used ones on their holders but am still searching for a new one.
Thanks in advance for this
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 4:52pm
You know, I've been working on those engine for 40 years and have never replaced one of them yet.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 5:10pm
Changed one out about 3 year ago . Carried bearing down to motion industries and walked out with one a few minutes latter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2016 at 8:26pm
Let me just say that when one does fly apart, it is not a pretty scene in the governor "room". I have seen ones that were so loose that I could not put them back in with any sense of confidence.
regards,
Ken McGregor
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:56am
I always have wondered how long those things are good for. I have never seen any problems with one, BUT......
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
