HD-5 crawler dozer
treedog62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Topic: HD-5 crawler dozer
    Posted: 09 Jul 2016 at 9:44pm
have a hd-5 crawler ts-5 dozer 2 cylinder GM Detroit I believe!! turns over smoke comes out exhaust but want start? any suggestions! does any one know how to check timing!!thxs
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 5:12am
You should check the trottle rod if she is engaged or the blower trap is closed
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 5:05pm
Can I still get parts for this old girl!! piston rings and gaskets in general!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 6:33pm
Me am still have some used parts for this machine but for piston ring you could have new ones from your NAPA AUTO PARTS (Detroit 271)
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 6:42pm
ok didn't even know you get new for it ! thxs that's good to know! just no compression! change out the engine! just maybe rebuild the other I take out. thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 6:55pm
You could check with MINN PARTS
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:38pm
 Remove the valve cover and insure that all of the linkage is not gummed up. The GM is timed by adjusting the unit injectors. You will need the  procedure from the Owners manual.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:38pm
just got this thing!! just wondering what type fluids to use in the rear and trans ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:56pm
been nice if I would have gotten owners manual !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 12:06am
Use 90 wt in finals and trany - or 90 trany 120 in finals
You need to be sure your getting fuel to injectors - it has 2 sets of filters - primary and secondary - also a return line on block to send excess fuel back -
 should have fuel gauge to give a pressure off primary pump - injectors are timed with a timing gauge - plug gauge that fits in top of hole in injector and rocker is set so a clearance or rise is calculated with the gauge .
  Somewhere now i have a file I am going to transfer to disc of HD5 manual - got the copy done but now need to burn the discs
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 8:52pm
thxs coke ! got the tranny out now motor is running! now got get couple of the gears in tranny and new bearings!! bearings on the shaft the drive shaft ties to!! ordered a couple hope they are rite ones. but I don't have a part no for the very front one! so rusty couldn't find it!! you wouldn't by chance have any parts or part no. thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2016 at 8:55pm
let me know when you get the manual burnt!! or send to my email!!ill pay ya!!thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 4:57am
I should have all the transmission parts for HD5
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 8:10am
sweet! what I need is that center shifting rod! this one is slitely bent! not sure what gear it is! and the fork!! its also the center! its got the slider forks on each end! made like a up side down U ! no nos on the machine to identify the gears ? will take a better look and see which gears!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 9:23am
how about the input shaft with bearings all ready on it ! if they are good ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 3:27pm
I have the center shift rod and fork andtakethe parts # on tomorrow morning and comback you
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 9:12pm
You might try some starting fluid, especially if it has been sitting for a while.. Take the valve cover off and make sure the injector fuel rods are free, if you have a friend familiar with 2 cycle Detroit's it would help !!   They will "run away" if not handled properly !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 12:37pm
I check this morning and have all the transmission gear ,the 3 shifter shafts and 3 forks
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 12:49pm
I"ll get back with ya ! soon as I get it apart and see what all I need!! I know I need the one with the double fork! and a couple gears!! you have any way of knowing which is reverse and which is the forward gears!! cause I don't have a clue!! thxs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 11:41pm
bes sure to check the bushing in the small gear on side of the trany on its separate shaft . they go bad and create problems
 also there is a brass bushing in the  master clutch housing - that needs to be a close tolerance and greased regularly
Edited by Coke-in-MN - 19 Jul 2016 at 11:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote treedog62 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2016 at 2:34pm
Good news so far!! I got another tranny from lady I got the dozer from!! gonna take apart and check all bearings and gears!! hope its good!! this is turning into a job!!!lol I am retired wasn't planning on working harder after I retired!!lol
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2016 at 10:30pm
Ain't no retired to it, just tired.
This page was generated in 0.293 seconds.
